DBedford
- Apr 12, 2023
- Age
- 67
- Location
- High Wycombe
- ZS EV Trophy LR
Seems to be the MG way !
Cars held together with clips ??
I’d previously tried tightening the 2 bolts either side of the steering column but that didn’t fix it for long.Top job !.
Did you need to remove the lower steering column cowl to tighten the two bolts, or could you get at them, by just removing the top steering column cowling ?.
Which I think is only held in place by clips ?.
Had the same problem on my 70 reg zs ev, dealer replaced steering column under warranty, took 5 months for part to arrive !Hi when I turn the steering wheel I occasionally get a click. Also if I put oressure on oneside or other of the steering wheel. Seems to come from the column near the steering wheel height adjustment. Is this normal ?
Dealer had a look and tightened everything and told me to see how it goes. No click for a while and then back it came. Dealer not aware it was a known problem. Anyone got a reference or info so I show it to the dealer when I go back? ThanksHad the same problem on my 70 reg zs ev, dealer replaced steering column under warranty, took 5 months for part to arrive !
Point them to this forum. Or tell them to read ALL the MG bulletins.Dealer had a look and tightened everything and told me to see how it goes. No click for a while and then back it came. Dealer not aware it was a known problem. Anyone got a reference or info so I show it to the dealer when I go back? Thanks
I have the same problem with my late 2022 ZS EVDealer had a look and tightened everything and told me to see how it goes. No click for a while and then back it came. Dealer not aware it was a known problem. Anyone got a reference or info so I show it to the dealer when I go back? Thanks
Yes I found the same, the rattle / click is more pronounced in the colder conditions.I have the same problem with my late 2022 ZS EV
I took it to the dealer, and they couldnt replicate the problem.. they couldnt find a fault.
I could be wrong, but I think its doing it more when the external temperature is colder ( eg 12 degree C or less)
Me to!Hi when I turn the steering wheel I occasionally get a click. Also if I put oressure on oneside or other of the steering wheel. Seems to come from the column near the steering wheel height adjustment. Is this normal ?
The dealers only tend to work on the items already agreed previously on the work list.Me to!
It was very noticable on the small winding Devonshire / Cornish roads.
Thanks Guys I will get the dealers to look into it especially as It has just had its first yeras service. Obviously it never got checked and why not if a known issue? Maybe they should have cinched down the bolts.
I have had the vehicle into the dealer twice.Yes I found the same, the rattle / click is more pronounced in the colder conditions.
I have found that the rattle emanates from the upper part of the steering column.
So farHi all. So after 2 visits to dealer I have just had replacement steering column installed under warranty ...yes sorted no clicking![]()
?So far![]()
Same , today I had the upper steering column replaced under warranty, no clicking.. yetHi all. So after 2 visits to dealer I have just had replacement steering column installed under warranty ...yes sorted no clicking![]()
