Martinonline
- May 17, 2023
- Location
- Sheffield
- MG4 Trophy LR
That's interesting and good to know.When the Shelly relay switches on the granny charger doesn't respond for 6 seconds, it then draws 7.3 watts for exactly 8 seconds and then draws the full 2.16 kW.
But what about disconnecting - I think that was the point @Coulomb was telling me earlier. If your Shelly just disconnects the AC supply, what does the MG4's inverter do then (apart from stress its snubber circuit / varistors)?To me it looks like the granny charger handles everything quite gracefully.
I'm always up for a challenge(But perhaps @Everest likes a challenge)
...But what about disconnecting - I think that was the point @Coulomb was telling me earlier. If your Shelly just disconnects the AC supply, what does the MG4's inverter do then (apart from stress its snubber circuit / varistors)?
But surely the effect on the car is the same as when someone is charging at a commercial charging point
When using the granny lead my process is this:
1. Park up
2. Open charge port door
3. Plug granny into car
4. Plug granny into extension lead (usually)
5. Plug extension into mains and switch on
6. Switch on at the extension
7. Car will make noises and lock the granny into the car port
8. Press lock on keyfob to lock the car
9. Check all is charging OK then go get trolleyed (as I'm usually down at my cousin's when doing this)![]()
Oh... Is there any 'protocol' used when granny charging?
Perhaps protocol is a little strong, but yes even "dumb" EVSEs have to implement the control pilot: the ±12V square wave of suitable duty cycle (representing max allowed current), and it must not enable the contractor until the car signals readiness by changing the amplitude.
I don't lock the car while charging quite often - you can then check how the charge is progressing without the charge stopping and restarting when you unlock the door. But I do have to lock the car when starting a scheduled charge.@Martinonline - interesting thread-within-a-thread... all good info. But am puzzled about having to lock the car to charge - presumably that is just for 'granny' speed charging? If one is out and about, I'd want to sit in the car when it's being charged, not stood out in the cold?
The instructions heading was 'Residential Charging' which I assume includes wall box EVSEs as well as granny charging. I have sat in the car when granny charging - when I was trying to catch the elusive 'Balancing' message. When out and about charging AC or DC I often sit in the car; you don't have to be outside. Perhaps MG are hedging their bets in case something nasty happens.@Martinonline - interesting thread-within-a-thread... all good info. But am puzzled about having to lock the car to charge - presumably that is just for 'granny' speed charging? If one is out and about, I'd want to sit in the car when it's being charged, not stood out in the cold?
I've never done that ... I always follow the process stated. Even when using my 7kW EVSE I never turn the car off first.Aha - breaking the rules, you missed point 1:
1 Ensure the vehicle is power OFF and all doors are closed.
Up to 80% 48A it looks linear, so for your example it looks possible. After 80% it looks like they tried to squeeze in a much bigger current range in the last 20% so it's non-linear.would a duty cycle of 15% trigger the car to charge at 9A? Guess not as 40A is not half the duty cycle of 80A
Looking at the chart, each 10% increase in duty cycle equates to 6A increase in charge current, all the way up to 80%/48A. Thereafter it changes. (i.e. 60% duty cycle is likely to be 36A, with 70% being 42A).Ah! Whirr, Clunk.. brain going a bit slow here today... Right, got it now. There actually is nothing different between granny charging and EVSE AC charging - apart from the current draw![]()
Just looked at your link thanks... where the image shows the duty cycle settings, do you know if these are the only possible fixed currents, or is it completely analogue depending on mark-space ratio?
e.g. would a duty cycle of 15% trigger the car to charge at 9A? Guess not as 40A is not half the duty cycle of 80A.
I don't know.
But surely the effect on the car is the same as when someone is charging at a commercial charging point and they return to the car while it's still charging and they tell the charger to turn off.
(I'm assuming that's possible, but I don't have much experience of this, I always charge at home on my little old granny charger.)
No experience either, but I wouldn't have thought so. If you tell the rapid charger to turn off, it will surely do its comms thing first and stop charging. I don't think there will be 350A at 400V flowing thought the cable as you pull it out. Nice fireworks if there is.
Thanks for that, and apologies to @Coulomb for not paying attention to it.The issue is what @Coulomb pointed out to me in post #5 above.
I thought you had to lock the car to lock the charger in place? Then once you’ve started charging you can unlock the car again and wait inside if you want.I don't lock the car while charging quite often - you can then check how the charge is progressing without the charge stopping and restarting when you unlock the door. But I do have to lock the car when starting a scheduled charge.
