TPMS pairing?
hojnikb
Slovenia
MG4 Standard
Does MG4 have any sort of automatic tpms pairing like other brands? For example, if i switch around wheels, will they be detected or will need programming again?
What aftermarket sensors are you guys running?
From what I recall, service info suggests TPMS requires reprogramming if wheels swapped around. Seems nuts as my MG5 also reports individual pressures for each corner but, I believe, will self-learn new positions and rotating wheels is recommended in the owners manual.
Here's my experience:
I've had my wheels repainted (powder coated), so all wheels off, and new TPMS valves.
Now, I don’t know what make of valves the garage used, and I was dreading having warning lights and error messages, but all I had to do was drive slowly ie 30mph max for a short distance, and the system recognised the new valves and all is OK now. I've checked with iSmart all all is perfect!
A small difference here is that these are new valves no programming needed.
hojnikb is swapping wheels around keeping the same valves. I'd say try swapping a couple of wheels, drive a short distance, half a mile (1Km) max 30mph (50kmh) as see if it self learns. 😣
Cool, thank you!
Would be silly to need to reprogramm them everytime you rotate the tires. I have to buy an aftermarket set of tpms sensors for my summer tires, so that's why i was interested in knowing how it works on MG.
    Votes: 912 77.6%
    Votes: 173 14.7%
    Votes: 91 7.7%
