siteguru
Distinguished Member
- Sep 3, 2022
- Solutions
- 3
- Location
- Strathaven
- MG4 SE SR
I'd worry about you but only if I'd got nothing else to do which is highly unlikely ?
Can I ask if anybody has used these and knows about these things: are they safe?You can get those cheaper on ebay
EV Cable Adapter 2022 MG ZS MG4 MG5 Discharge V2L Vehicle to Load UK Power Cut | eBay
You will receive adapter(s) as shown on pictures and item title.www.ebay.co.uk
I’ve just ordered this exact one but I don’t get the car until 5th June. Hoping there is a positive response from someone who has used this !Can I ask if anybody has used these and knows about these things: are they safe?
I know just enough about this to know that I don't want to take a risk. But I'm also very reluctant to spend the huge sums that MG want for the official cable!
Thanks in advance.
Rated IP56 whatever that means.The car charger is waterproof, the adaptor is not. Might need to find a way to cover the adaptor...
I guess that it is ok to use the jet washer to clear the driveway or other car
IP56 = Protected against harmful dust (first digit) with protection from strong water jets and no harmful effects of strong water jets from all directions (second digit). Protected against ingress of solid object, diameter 50mm. Protection against water drop. No harmful effect of vertical water dripRated IP56 whatever that means.
Totally agree and have said so in many threads on this forum and have done the very same when we purchased the MG4.Call me cautious but I bought the hideously expensive MG V2L cable. I don’t want to risk electrocuting myself with a dodgy cheap adapter bought from eBay. Nor do I want to damage the car or any connected appliance.
I bought one , have tried it , it works, plug n play.Can I ask if anybody has used these and knows about these things: are they safe?
Thanks in advance.
Which is why when buying third party adaptors yoiu have to make sure they are MG4 specific.No it won't. You need a different value resistor between PE and CP. The Hyundai/KIA system is slightly different. You would be better getting an MG adaptor.
See the first page for the £20 eBay one, I've just got one and it works fine (check year is correct as they have two different ones)And does anyone have a recommendation for an adapter for the MG4 that won't cost 300EUR?
Hello, I have this tested one, it's a bit impractical because it doesn't have a cable, where can we exchange experiences, write a private messageAnd does anyone have a recommendation for an adapter for the MG4 that won't cost 300EUR?
