TheArcher
- Apr 17, 2022
- Location
- Swanborough, East Sussex
- Not an MG
May I ask which VTL cable you are using as I didn't think we can get them yet (in UK).
I am using the 0.5m type 2 to 16A CEE from EV Cables UK. Into that I plug a standard mains kit sold for tent camping on EHU.May I ask which VTL cable you are using as I didn't think we can get them yet (in UK).
When I had the flat 12v battery (after that 15 hour V2L session), the door locks still worked (sounded a bit sluggish) but the Start/Stop button didn't do anything. I now keep a LiFePO4 jump starter in the car as a flat 12v battery completely disables the car. The jump starter was £45 from Lidl.Ok, day 2 update:
Yesterday evening, with 100w draw on the V2L, the battery voltage started slowly dropping as the evening went on. We noticed that the car was doing a pulse style charging, every now and again, seemingly at random, the voltage would momentarily spike to 14.3 ish volts then drop back down. That then seemed to stop and the voltage slowly dropped down to below 13v. I decided to put the car in the on position until bedtime, and duly the battery was held at 14.1v until I switched it off again.
This morning, a 2% drop in HV battery level and the main 12v battery showing 12.2v on the app - unfortunately I didn’t get a chance to put the multimeter on the battery to confirm this. Given that the battery spend at least 12 hours on charge yesterday, 12.2v tells me either there was a load on it again overnight and/or the battery is knackered.
More likely the latter, as on putting the car in ready mode, the voltage dropped to 10.2v and the car threw up lots of error messages, intermittently shutting off and reconnecting the HV battery. Eventually it settled itself down and is currently sitting in ready mode with the 12v battery charging as you would expect.
Two things come to mind: quite clearly the 12v battery is not as healthy as you would expect a new battery (as discussed above, we know why that could be). Secondly and in my mind more annoyingly, is that the car doesn’t seem to be able to recognise a discharging 12v battery in off mode (not for an extended period anyhow) and will quite happily let it discharge to the point of not staring the car, even though it has the means to correct it.
In summary, it seems there is a load on the 12v battery with the car off and V2L attached (even with no AC devices attached). The car will pulse charge for a while but will ultimately allow this to discharge the battery to the point of needing a jump start
Some observations on this thread:
1. I also had a flat 12v battery after a long V2L session (about 15 hours). However, after a shorter V2L session, the 12V battery was OK. It looks like the 12v battery is being charged during V2L, but maybe this times out after a period of time.
2. The V2L output is pure sine wave, about 220V, 50Hz and can supply 3kW (but I've not tested for how long it can sustain 3kW.
3. When V2L is running, any attempt to check the HV battery SOC (using the app or the car's instrument display) interrupts the V2L power for a fraction of a second. This may explain why appliances behave strangely (like the electric blanket reset).
4. Using a mains socket tester on the V2L output will yield strange results. Live and Neutral are interchangeable from a stand-alone generator, so swapped Live and Neutral is meaningless.
I have a question…
Why do you not leave the car in the On state and locked when using the V2L feature?
I have a question…
Ah, the DRLs will be an issue :-(Unfortunately you cannot lock the car and it leaves the DRLs on (which is not ideal on the campsite overnight)
Is it an AGM battery in the ZS EV?Further insights:
There is a 0.9A load being applied to the vehicle 12v battery whilst the V2L is plugged in. Quite what this is for I don’t know - I can’t imagine holding the contacts open would account for this.
After about 3 hours the vehicle seems to stop maintaining the 12v battery so it is left with this 0.9A draw for as long as you continue to have the V2L load plugged in (even if no appliances attached). A healthy battery should be able to sustain this overnight but clearly mine is not healthy and the dealer has agreed to replace it.
I am tempted to fit a better brand though so if anyone can recommend a particular battery that would be helpful! I have always ordered Varta batteries in the past for ICE cars.
I have started this thread because I have seen so many comments about how crappy the 12v battery is so I am looking into viable upgrades ranging from bigger lead acid batteries to Li-Fe or Li-Ion to save a bit of weight in the process. We can also use this thread to discuss options on how to keep the 12v battery in tip top condition whether that be a smart trickle charger if the car isn't going to be used for a while etc.
Wow, that's strange. If your voltage measurement hardware is flaky, that would explain the weird charging on V2L, but not the solid 14.1V when in the ON position.We noticed that the car was doing a pulse style charging, every now and again, seemingly at random, the voltage would momentarily spike to 14.3 ish volts then drop back down. That then seemed to stop and the voltage slowly dropped down to below 13v. I decided to put the car in the on position until bedtime, and duly the battery was held at 14.1v until I switched it off again.
Someone has, have a look at this video.Would be interesting if someone with an oscilloscope and a V2L adaptor, would take some pictures of the "sinewave" that is produced by the car.
Heh, good idea. I mean, it's totally sad that we have to come up with workarounds like this, but until this is sorted, no weekends need be ruined!If this doesn't work could you plug in a 12V trickle charger battery charger into the V2L to keep the 12V battery topped up to give you more reassurance overnight?
Great idea to keep a lithium jump starter in the boot. Essential for an EV and cheap, easy and convenient fix for a flat 12 volt battery. I quickly showed mine in a YouTube video on accessories I added on our ZS.So first time using our new V2L cable on the campsite last night and awoke to a flat 12v battery.
It seems that with the V2L cable attached there is some form of drain on the 12v battery although I cannot work out what or why?!
The process we followed was:
- car on, discharge screen set to 40% minimum and start discharging
- car off and locked
Vehicle is a facelift ZS EV Trophy long range registered at the end of May.
Overnight we consumed about 1kwh of mains power (HV battery dropped by 1%) but 12v battery was reading 5.5v this morning.
AA had to be called as we had no way of jump starting but they did it successfully.
If this is a thing then it makes the V2L useless. Any ideas on why it would touch the 12v and how to stop it?
Hi. I am looking at running a V2L but cannot find anywhere that backs up your statement of it being pure sine wave. How did you find it out?. Thanks.Some observations on this thread:
