Xpower Battery Specs, Economy and Regen question
I just went out and tested it with the power display on, one caveat was the battery was 40% and below.
A standing start the displayed showed no power going to the front wheels until negotiationing a corner then it showed 4wd, after the corner changed back to rear only. Tried the standing start 4 times with the same results.
Maybe it also has something to do with battery level, so I'll charge up tonight and do the same test tomorrow.
Same here after testing AU model again, no AWD in straight line until cornering, this was flooring it pedal to metal from standstill, battery around %55
Mind you this was dry flat road, possible that wet road could be different
That would be interesting. 0-60 times in
Eco, Normal and Sport and in Launch mode. To see if there really is much difference. Over to you, Chris. ???
Go back to Dragy thread m8, No don't worry, I'll link it it down below, but just did a Dragy ECO 0 to 60 at 6.47 seconds.
4WD was indicated on the energy screen and power was really restricted, which I suppose is fair enough being ECO.
I've Dragy'd it in all modes and the top times are in the thread.
Anyway, only a TiT would be using ECO for any high speed shenanigans!
But saying that, even in Docile mode, it's still faster than a lot of so called fast cars! ?
Fastest MG4 X Power in the World 0 to 60mph?
See here.......
Happy to send the Dragy video if you want it. PM me.
Too hot for TV.....
Well you did and you have the video to prove it ???
All.i can tell you is when I did it there was no power indicated to the front wheels, but as I said maybe that's a battery level thing.
No I don't.
I deleted it!
I didn't want to look like a TiT!
You are quite clearly not trying hard enough!
Mine instantly engages all 4 wheels.
Where are you in South Wales m8?
See here.......
Too hot for TV.....
Respect Bricktop, those times are superfast!
Can I please ask if those times were done on a stock car with bridgestone T005's and are just down to driving skills?
Interested to see what times you will get with the Michelins on
Why Thankyou.
That's with the PS5s.
There isn't much skill required tbf, but my fastest time was not how I expected to achieve it.
I don't tell all on here as there are one or two folk on that board desperate to beat my time.
No clues given! ?
I've PM'd you a link to the video.
