BG4
- Sep 12, 2024
- Location
- Perth, Australia
- MG4 XPOWER
Same here after testing AU model again, no AWD in straight line until cornering, this was flooring it pedal to metal from standstill, battery around %55I just went out and tested it with the power display on, one caveat was the battery was 40% and below.
A standing start the displayed showed no power going to the front wheels until negotiationing a corner then it showed 4wd, after the corner changed back to rear only. Tried the standing start 4 times with the same results.
Maybe it also has something to do with battery level, so I'll charge up tonight and do the same test tomorrow.
Mind you this was dry flat road, possible that wet road could be different
