Apple carplay?
It's not just MG and it's not just wireless though. While I wait for my XPower to float its way round from China, a friend lent me their Mini this weekend, complete with wireless Carplay. At least 3 times, I've had to remove and add my IPhone as Carplay just froze.. They've all got their issues, just so complicated nowadays.
The Mini also refuses to go into drive sometimes if you've dared to do something out of the ordinary, like turn it off and not get out. Open door, shut door, start again and it works :D Computers with wheels, fun fun!!
Good to know its not just us. I’ve been spoilt with some amazing cars, I guess you get used to things working smoothly.
Well I may have discovered the solution for iphone users, MG4 SE model, 7 days in and done it about 10-20 times, worked every time.
1. Make sure that any-fluff is removed from the lightning port, you have to be quite harsh in removing this.
2. Use a short cable - I use a ZKAPOR amazon one.
3. The trick I've found is that the screen on the iphone needs to be off, as when your plugging it in, if the screen comes on, press the right button on the side to turn off the screen, when the cable is plugged in.
Broken record here - it's nothing much to do with cable length, a speck of fluff, cable manufacturer etc. (yes all can impact if extreme)
It's to do with the infotainment system being sufficiently booted to take a CarPlay connection - which takes several seconds. Just ensure the infotainment is up and running - then plug in
Yes definitely important. I wonder if many of the “only works some of the time” complaints are due to not noticing this.
Once I realised it, my CarPlay works 100% of the time when I wait for the system to be Ready before I plug in the phone.
AND made quicker by unlocking the car earlier as I’m walking towards it instead of using the button on the door handle. This way the car is normally ready the second I sit in and hit the brake pedal instead of having to wait.
Just to state (as others already have on here & similar threads) - it's less about the cable (anything from a reputable manufacturer will be fine), and more about giving the infotainment system time to fully boot-up / load.
Simple steps which work 99%+ of the time:
1. Get into car(!)
2. Foot on brake to trigger the infotainment system to load
3. Wait until info screen is fully loaded
4. Confirm by using the volume control on the steering wheel to adjust, well, the volume (if you don't hear anything then either the vol is incredibly low - or the system has not finished loading)
5. Then, and only then, connect your iPhone
I did that with 27 different different cables! All original apple or high quality, not a single one worked when doing as you say.
Bought an anker one, worked immediately and has done so for months now. Not once has it not connected.
It definitely IS the cable.
27?
??? well if you have a look at the countless threads on here stating that it is the cable , you might reconsider.
I have also had two MG dealerships say the same.
I did. Eliminated cables quite quickly. Maybe think about what you did? Tried 27 cables and suddenly, miraculously, one worked? Respectfully I suggest it wasn’t the cable then. Perhaps you solved the underlying issue w/o necessarily realising it?
Anyhow, as mentioned, great you got it resolved! Certainly infuriating to have CarPlay so hit’n’miss. Happy motoring to you.
But… did you miss the part where I said I only plugged the phone in AFTER the car was in operation?
I mean, it’s not like there can be 20 other things that could be wrong.
It’s one or the other.
The cable works perfectly now.
Most cables are slow speed (white insert). A high speed cable is essential.
Didn’t know there was such a thing as high-speed Lightning cable (can’t find a spec for it on Apple’s website - Lightning speed is USB 2.0 I think). CarPlay should work with any Apple MFi certified cable. If you’re using a cable that’s not MFi certified, well……
Yeah that’s the part most people are missing, plus also the number of fake ones that are on the market.
After realising the system needed to be ‘Ready’ I went back and tested heaps of cables and I’m yet to find a cable that doesn’t work out of Anko, Belkin, Cygnett, Apple brand. All perfect.
Whats the easiest / cheapest way to get apple carplay to work? I'm sick of the car hating all of my cables and refusing to work ?
Dealership told me to get a Bluetooth wireless thing off amazon but they're like £50...
Hi, after months struggling with my new iPhone, in desperation I tried my daughters discarded 7, bingo! It worked like a dream and continues to do so. Best part being that if I ever have it stolen, the phone that is there’s nothing of any personal info on it apart from a dodgy email address and the only apps being sat nav, maps and radio players, happy days!
Worth repeating: Use any good Apple MFI certified cable. I’ve tested plenty that all work 100%
CarPlay only works in an MG4 if you plug the phone in after the infotainment display has booted and is ready.
If plugged in before then it won’t be detected.
Anker iPhone Charger Cable: £10 Amazon
- Fixed mine MG4 SE. iPhone 12
    Votes: 930 77.6%
    Votes: 177 14.8%
