rjkirk
- Jan 18, 2023
- Location
- Eastbourne, England
- MG4 Trophy LR
They are seeking assistance with their car, not their English! Don't be a pedant.
Are you for real?They are seeking assistance with their car, not their English! Don't be a pedant.
Mine does something similar. After a recent update the car will no longer stop at 80% charge despite 80% being set in the app and in the car. It's going in this morning for a software update to correct this.I was wondering if this common to all MG4 models, or just my trophy.
When I select “battery health mode “ in my vehicle, it always charges to 100%
And the option no longer seems available under EV management in the app anymore?
I also select 80% in the Octopus energy app and that also get ignored.
Im sure this hasn’t always been the case.
This is confusing as 80% is the recommended value to use on a day to day basis, and only 100% occasionally.
Interestingly, this itself is an engineering misunderstanding. Cogs are not normally adjustable at all, their use stems from the notion of the cog representing "internals" but actually adjustments are better presented by knobs and levers, such as in the alternative "sliders"-style icon that some applications use, denoting direct adjustability.The interpretation of the graphical symbol probably came from the fact that a "cog" symbol is routinely used in software HMI to depict a setting or series of settings that can be adjusted. The symbol they actually chose seems a bit quirky to me but then again this is MG we are talking about!
It will stop granny charging if the supply isn’t sufficient to run the battery heater and the battery is cold, or the battery is overheated and needs the battery cooling running. Normally experienced in winter at SOC above 95 when below 0C outside.The consensus of what I have read so far is likely that the 51kW NZ/Au version doesn’t possess health mode even if it’s on the app and screen. Which is somewhat confusing as ours has stopped granny charging at low 80’s for no apparent reason a couple of times.
Thanks so much! That’s put my mind at rest!
Sorry RolfeJust charge your car as and when you feel like it, to 100% (and be sure to give it time to complete a balance charge too, usually 30-35 minutes beyond the finish time that shows in the app) and don't worry about it, even if you leave the car sitting at 100% for days. The LFP chemistry in the SR really doesn't care.
You can tell it's finished balancing when the app no longer shows a finish time, and reads "not charging". If you see a finish time the same as the current time and the car is still "charging", even if it's reading 0 kw, just leave it, it's still balancing. During winter you will sometimes see other things happening, like the charging power going up and down for no reason when it's close to full. It's heating the battery or something. Just leave it, it knows what it's doing, it'll be fine.
Sorry Rolfe
but that might be not right about LFP
seen this video
now to be correct - in laboratory not used for check neither catl or byd cells so that hopefully should not worry MG SR 51 kWh or someone that have byd brand car with lfp blade cells
but after cycling mine atto3 for 1 year 95-100% i get SOH calculated by Car Scaner 95,71%
and some china made app told that i have 2% degradation (probably another 2,5% is bottom buffer that car scanner unavare of existence)
in video they say that cycling 75-100% causes more degradation then cycling 0-100% or 0-25%
anyone intrested can read pdf that channel owner used and link added below video.
if that true lfp have only one benefice - less dangerus chemistry.
And from now i stopping topping up battery every day to 100% because have so low mielage that one full charge can by sufficient for me for month.
