Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
I think you're probably screwed I'm afraid.
I'm just back from our village charger. It's the only one there is for miles around. The notice clearly states that there is a 45 minute time limit on using it, and doesn't qualify this in any way as to which connection is being used. (It has CCS, type 2 and CHAdeMO.) There is also a 90 minute prohibition on returning. The only concession is that there is a 10-minute grace period. So I make damn sure to disconnect 54 minutes and 30 seconds after charging starts, knowing that if a fine kicks in I've already incurred 10 minutes worth.
The time limit is there to stop any one person hogging the only charger in the area for an inordinate length of time, and in that respect it doesn't matter whether they're using the CCS or the type 2 connector. It seems harsh at times when there is nobody else around who wants to use the thing, but I don't know what else they can do. I have sat at home watching the app and waiting for that charger to be free, and if someone had sat on it for ages because they were only using the type 2 connector I'd not have been happy.
It was rough that the CCS connector was on the blink, but I think the best you can do with that is take your maximum allowed time and - if you're not able to wait until the no-return-before period has elapsed - use it to get yourself to another charge point. Then when you've gone, some other poor sod will be able to do the same thing.
What is the type 2 connector even for? Well, someone might want it for an hour to balance-charge a car they had filled up on the CCS earlier, or in the situation you found yourself, a few miles is better than nothing at all, I suppose.
