Diagnostic VDI, VNCI, MDI with MG4
I'm one of several Trophy owners who've had the r63 update (see the Software Update thread), but I think you may be the only one who's had the T-Box updated too.
Has the Bluetooth pairing issue gone away on your car? I'm asking because the evidence seems to be that r63 doesn't fix it, so I wonder if r63 plus T-Box 23E32 is the solution.
Morning
Yes ive not had bluetooth disconnect since, im comfortable in saying that the TBOX update sorts bluetooth and also the SOS intermittent issue where it first goes orange then red at times, always cleared on a restart, sometimes cleared while driving. I will post on here if i get either issue again.
Ive just noticed on my Samsung S23 that i have literally over 100 MG Bluetooth connections, gotta delete em all one by one. Will do so then re pair to the car and see if i end up with multiple bluetooth connections going forward.
Look like each time it prompted to pair, it made a new connection, i just assumed it was reconnecting to existing.
Keep a screenshot as evidence in case you need it for the dealer!
Just removed em all mate. I think im all good now though im on latest TBOX Firmware and R63. Gonna delete phone from car now, do a new pairing and ill update on here any issues going forward.
With R46 and SNA(M)PK18E32, I had exactly the same problem (6 BT connections) as well as the occasional intermittent SOS ignition. Since the Tbox update and switch to R63, my 4L v1 connects well to iSmart and there are no BT pairing problems.
Morning
Well today i opened app, set car to turn on heating and boom, got the pairing request on my phone. Pressed decline, checked BT and yeah had 2 entries for car on phone. Deleted the second one and car was fine when i got in it.
But does seem even if it may be better, the issue may not be resolved.
Dear colleagues, I am looking for help with programming my ehs. I have cable and use SIPS. During the last update, I updated the front radar via replacement features. This resulted in a lack of radar calibration. Now I don't have cruise control and other functions. Error B19CA. I can't find a description of radar calibration anywhere. Can anyone help me? you're welcome :) and sorry for my English :)
Why unless it was a replacement or bricked would you update it as a replacement?
Routine, F D R cal, start calibration then go for a drive staying 40-60 kmph (25-35mph), display with Speedo will give progress popups (25% 50% 75% done) once done stop, power down via FICM, wait 1 min, lift off seat & sit down again to wake car up, it comes up successfully or failed on display with Speedo, if it fails try the same again
Took me 2 goes
MG's instructions
It was updated like this by accident. I'm still learning this system :( Thank you very much for showing me the path. I didn't see these options. I'll check it and let you know if it's successful.
Where can I find a version of SIPS like in your image? Mine does not have the ONE PRESS option :( I have my version from the RMI website. Thank you again for your help :))
hello everyone
I have software R63 on an MG4 Luxury version installed by the dealer. But now I can't change the target percentage from the infotainment; change is only possible via the MG iSmart app. Any suggestions to resolve this and return the ability to manage the target percentage through the infotainment?
Have you tried tapping the screen rather than trying to slide the slider?
Or is the issue that there isn't anything to tap/slide?
Yes, I’ve tried both tapping and sliding, but it’s as if there’s nothing to tap or slide, or as if it’s disabled. However, in the discharge management, it’s possible to adjust the value.
    Votes: 933 77.6%
