Diagnostic VDI, VNCI, MDI with MG4
yup. 1.0.0.6 , charger connected.
Good good. I remember someone posting they had trouble with the laptop they were using (granted sounded like they were using a wreck). Maybe try another?
If there is timing issue or something similar, different hardware MAY just be enough to get you through ? Seems odd as despite the issues most have battled through
I use a Lenovo G500 MT 2236 intel celeron 1.9GHz 2 core
Runs SIPS fine but not VDS
Only issue I've had was due to low battery because I didn't use a charger/maintainer when I first carried out updates
WiFi seems quicker for me but as generally it's not recommended for programming I try to avoid using it
There was a comment about a guide for software updates so I thought I'd write it here where all the other info is
To connect to the car you need a Vehicle Diagnostic Interface (VDI), from what I've read a VDI2 or VDI3 for MG4, I personally ended up getting a VNCI due to supply issues, it's also substantually cheaper
it's recommended to update connected via USB but I have done some connected via WiFi which worked fine
Once you have the interface you need to install the software on a windows computer, VCI manager & SIPS for software, VDS if you want diagnostics as well (VDS requires a more powerful computer, not sure what spec)
VDS zip password is VDS3
SIPS zip password is SIPS
(Google remove it otherwise)
Open
If you haven't got an account you need a company account to get the Offboard Diagnostic subscription, 1 hour is £5.92, 1 day is £16.24
When you have paid click top right where it shows your name then user profile, you'll see SNW this is the login for both SIPS & VDS
Some of the MG sites if you login it'll get you to change the SNW account password which also affects the software, if you get a long subscription it maybe advisable
Open the VCI manager, click connect (wireless connection will show signal, USB connection will show USB icon)
Once connected it'll change to a tick
Open SIPS, login using SNW details
click vehicle identification, it'll confirm VIN click yes
you'll get lots of error messages on the car as it checks the different modules, confirm car (EH32) click yes, it'll show the configuration of the car with different pages available on the left side
You can view current versions on the car Vs server by clicking ECU Information
Connect power to 12V battery (charger/maintainer) so battery doesn't go flat during an update
If updating a single module go to Programming and Config, this allows you to program, load the config, program a replacement module
If updating multiple go to One Press, select the ones you want or select all then click next
It'll say several calibrations are required after updating, I've used the car for a while without doing these but I have also done them, doesn't seem to be any difference either way
Can't currently update TBox due to requiring a USB to be used first, don't currently have access to these files or where they're stored for dealerships, I know where thanks to a dealership but I don't have a login
If you want/need to calibrate go to Routine & select required module
I tried to signup but there were no payment fields even though I chose a company account, could it be that they removed such a feature?
You need to click "start standardised navigation"
Then click the second option "payment"
And then you can buy some time for access to documents or for diagnostics.
Tech support resolved the "user logged in problem" and extended period.
But its not possible to reprogram or replace the unit (FDR) with wrong VIN,
the box with functions is empty when you select such ECU.View attachment 35245
what did you do with the radar showing up as ‘VIN doesn’t match’?
I have the same problem...
I’ve actually had no luck - FR still not detected and unsure how to make it so it is
Is not detected or detected with a VIN mismatch?
If it's not detected you should check the wiring harness to see if it gets power properly. On a VIN mismatch there's nothing you can do
Nothing you can do with a VIN mismatch?? Does that mean the radar has come from an SE (I’ve put it on a trophy)? Surely that’s the only explanation. But even that seems strange
Yeah...some parts are coded with the vin of the car they were first installed on to discourage parts theft (on paper, at least).
SIPS will refuse to operate on such a part.
If it is from the same car equipment it should work even with the Vin mismatch, but wouldnt allow update/reprogram.
Ironically, i have the trophy radar mounted on the SE. It is recognised and i can even initiate calibration but it doesnt work because it is missing side radars.
If it is not recognised at all you have wiring issue or radar malfunction.
What is the "Large Size Data Synchronization Tool" actually for?
When asked to start it, I always choose "no."
In this manual it is stated that right now it is applicable for these Models: Only the MG HS 24MY and MG Cyberster are effected in the current range.
    Votes: 931 77.6%
