Has anyone found out if there is a engineering menu on the Cyberster, there are many videos on how to get into the mode on other MG models normally you press the 4 corners on the infotainment screen but the Cyberster has 3 touch screens so which one
In the MG4 you find the infotainment version and tap several times on that to bring up a password entry box. So whichever screen you find that on would be my guess![]()
200519 does not workHave a search through the MG4 posts someone had posted a code you could try on one of those.
Try searching on "engineering menu" or "secret menu code", can't remember which post it was on
Hi, try this one 12345@saicThanks now I need to work out the pin. Any suggestions?
Tried it. Does not workHi, try this one 12345@saic
Yes.Has anyone found out if there is a engineering menu on the Cyberster, there are many videos on how to get into the mode on other MG models normally you press the 4 corners on the infotainment screen but the Cyberster has 3 touch screens so which one![]()
#*#4479*#*
to get into "Engineering Mode". I tried it myself and see this appears on 2 displays :I have not been able to get this to work on our Cyberster. Has anyone been able to get this working. Did you need to have a phone connected first or the car turned on. Tried lots of options with no success.As I observed the MG technician, he selected the telephone keypad and entered#*#4479*#*
I have not checked anything out from there yet but I would like to be kept informed about any discoveries from there.
[ Moderator: Used icode (Inline Code) tags to prevent auto italics. ]
This is not the telephone keypad bit.The password generator site had this sentence:
"The password ##4479#* is only valid for the 2022 and 2023 Standard models. For the 2024 models (all models), the password is !Mg12345 and the time-based password generation procedure is not required."
Don't know if it works but you can always try.
I just tried it here in Phuket on my friends Cyberster and it works too. ; switch on the car by having the key in your pocket and hit the brake, select the phone tab on the left screen and select keypad, enter the code "dashstardash4479stardashstar" and then the aircon screen and right screen show two different [ENGINEERING MODE] screens.I have not been able to get this to work on our Cyberster. Has anyone been able to get this working. Did you need to have a phone connected first or the car turned on. Tried lots of options with no success.
