Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
I take it this is your first car with this type of system? It's perfectly normal for them not to be marked. In fact I have never seen any car with them marked.
Many people routine swap tyres front to rear (and sometimes left to right) so the markings would be wrong after the first tyre change anyway. Most garages will strongly advise that you fit the newer tyres to the rear of the car, which would mean swapping the front wheels to the back. (unless you wanted to pay to swap the actual tyres on all four wheels when just replacing two of them)
Also, as I said before, you certainly don't need to go to the dealer for every car when swapping wheels. If you do a TPMS reset (via the menu) on many cars they simply learn the new wheel location. My previous car didn't even need that, and would auto-detect if a wheel has changed location and re-learn after a set period of driving.
Unfortunately for you, I therefore imagine a lot of tyre fitters don't pay much attention unless specifically asked about it. Let's face it, so many cars have TPMS now, imagine if every car they did had the owner come back and complain. They'd soon have to adjust their process to stop it happening as it'd be a huge waste of their time.
I take it you had all four tyres changed at once? To be honest that's probably quite unusual in itself as normally the driven wheels wear at a faster rate.
Yes, I have not encountered this before, but then my last car was 14 when I finally had to get rid of it.
I would have thought that one would swap the tyres, not the wheels, unless I suppose an owner was doing it himself. Although I suppose I'm wrong about that, I'm thinking about the autumn/spring tyre changes. But even so, it should not be beyond the wit of man to devise a marking system that can be updated if the wheels are moved.
It's entirely normal around here for all four tyres to be swapped at once. I've been doing it twice a year for 12 years at least. Winters on in November, switch to summers in April. This was my switch to "winter tyres" although I've chosen to put all-seasons on this time. So this garage are doing this all the time.
So if the garage don't routinely mark the wheels, yes, it's going to be a huge waste of their time, and I hope they have to waste a ton of it next Friday. I suppose it's possible they did mark them, but somehow two wheels still got switched.
My last car had a system that seemed to be something to do with wheel rotation and whether all four wheels matched. I paid £25 for it as an extra when I bought the car! It simply flagged up that there was a problem, and it was also quite prone to false alarms, especially spring and autumn and every time the tyres were changed.
But I can't imagine that the MG4 is especially unusual in 2023 in having this system. I just assumed the garage would know what to do.
