Is standart and trophy versions have same left tail lights?
kozd
Nepal
MG4 SE SR
I need a left tail light spare part for my mg4 standart. I found one but there is two different part numbers for the tail light. One is 10976793 and the other one is 11179733. I believe the one starts with 11 is for trophy but the two looks identical. Are there anyone that knows trophy tail stop lights are compatiable with the standart one?
Apart from the standard being £13 cheaper on MG Titan I don't know.
Maybe the two numbers are for left and right hand drive cars.
I figured it out, the part numbers mg titan gave is misleading and for getting extra 30 dollars. My standart cars original tail light starts with 111 mg titan says its for trophy version but it has nothing to do with it. I specifically found one that starts with 109 it is working no problem but if you found cheaper that starts with 111 you can use it it is compatiable with each other.
I believe there will be a difference between Standard (SE) and Trophy. The Trophy has the light bar across the rear, and illuminated patterning on top of the light cluster (as in my profile picture), whereas I the Standard (SE) is plain. There may also be a difference between left and right hand drive cars depending if there are reversing lights fitted to both sides or just one.
    Votes: 939 77.6%
    Votes: 179 14.8%
    Votes: 92 7.6%
