Trooper
Yes,“Start Stop Card” is the best of both worlds.Thanks @Trooper . Did you set up ChargeHQ to run in 'Start and Stop Card' or 'Billing Card' mode?
The Charge HQ doco (MG ChargeHub Configuration for EV Solar Charging) shows 'Billing Card' mode in the Picture, but states 'Start and Stop Card' in the text underneath.
If you use 'Start and Stop Card', can you override any Charge HQ settings by using the RFID cards?
The ChargeHQ instructions did originally say “Billing Card”, but that would leave you unable to charge if for some reason the charger can’t reach the OCPP server to get the charge amps setting or schedule setting (e.g. if there’s a WiFi / internet / ChargeHQ outage).
But “Start & Stop Card” supports OCPP plus allows you to use the provided RFID cards if you wish, so when I found that worked I contacted ChargeHQ to let them know but I guess they just changed the text and not the screenshot.
(Edit: Just realised I said earlier “I do only use ChargeHQ for scheduling” .. but what I meant is I don’t use the iSMART app scheduler. I do also use ChargeHQ’s Solar Plan feature to vary the charge amps according to solar production ?)
