WonkoTheSaneUK
- Aug 2, 2022
- Location
- North Wales
- MG4 Trophy LR
The car is bound to your account, not your phone.Thanks for the responses. The app reports it is compatible with Android 8 and above, and my device is listed as compatible. Certainly iSmart V2.0.1 worked (" ") ok with it, but no joy so far with V2.0.2.
As you suggested Ian, tried clearing the cache before opening it after install, no different. I haven't dared to clear the data as well, as I think I will have to rebind the app to the car - is this true? That's the next step to try anyway. It's no good if it won't run, bound or not!
It's quite likely if no-one else is having the same issues that it is a problem with my phone. Anyone else successfully running iSmart with Android 8?
You shouldn't have to rebind, just login using the method (email or phone number) that you originally used.
If the app asks you to rebind, you've used the wrong method - try the other.
