Grriff
- May 20, 2023
- Location
- Nottingham
- MG4 Trophy LR
You will find the car 'goes to sleep' after around 24hrs of inaction. iSmart won't wake it you have open the car.
I have checked in the App for the update from my current version of 2.0.2 on my Iphone14 and it reports that I am already on the latest software ?.2.0.3 out for IOS. Updates to charge management and bug fixes apparently…![]()
Android or IOS @Grriff ???.Got the update. My car is no longer in Brussels!
Sorry, I only have one account, my phone number...... (unless I haven't understood you, which is likely)(Ommmmmmmmmmmm - chants to remain calm and serene .....)
tl;dr - if you can't already see your bound car in the app, you're logged in to the wrong account.
If you've previously used the app, and can no longer use it in the new version, but you are logged in, then ... you are logged in to the wrong account! Simple as that.
You MUST login using the original details you used when creating your account. If that was via email, use that ... if via phone number (without the leading 0), use that. I don't care if you've previously been able to login via either method in the old app, you MUST login (first time) using the original login details.
As mentioned by guru, try searching the AppStore, that’s how I got my update.I have checked in the App for the update from my current version of 2.0.2 on my Iphone14 and it reports that I am already on the latest software ?.
It is not offering version 2.0.3 as of yet.
Phased roll out maybe ????.
If it arrives, it will be interesting to see if it reports my closest charger is less than 5,500 miles away !?.
Don’t expect much from the closest charger - apparently mine is well over 5k miles away too![]()
Who knows what sort of wizardry is going on with the app. I just pray it keeps letting me access the car, preheat it, unlock and drive it on the very odd occasion I need the digital key. The other stuff on the app isn’t something I normally use.Mine worked perfectly. ChargePlace Scotland, 438 yards away. (Also indicates one up on the main road 657 yards away but if that exists I wasn't aware of it.)
Does the Play Store say the app is compatible with your phone?Oh dear, bad to worse. Just tried installing V2.0.2 from the Play Store on my Android phone (8.0.1) and now the app won't even open, just a black screen. Tried uninstalling and reinstalling, restarting phone in-between, several times, getting nowhere. Anyone having the same issue? Ideas?
The app says it's compatible with Android 8.0 and up so it should work unless they haven't updated the requirement in the play store.Oh dear, bad to worse. Just tried installing V2.0.2 from the Play Store on my Android phone (8.0.1) and now the app won't even open, just a black screen. Tried uninstalling and reinstalling, restarting phone in-between, several times, getting nowhere. Anyone having the same issue? Ideas?
