Thank you for the advise lovrmyev I will put it on my 7kw pod point tomorrow after I run battery down 1 bar as you suggested.If YOU want to speed up the process a little, when the car is fully charged & balanced.
After you have used it to make a small trip and you have lost one of the white bars displayed on the range indicator, put the car back on charge again.
It will then top up the HV battery and then start the balancing process more quickly.
As the HV battery starts to recover, the balancing process time will slowly start to decrease.
At first, don't be surprised if it takes a LONG time.
It will attempt to balance the pack for about 12 hours and then give up until the next time.
Don't worry, it is only pulling about 500 Watts when the balancing starts, then this demand will reduce as it gets closer to finishing.
It's a stepped process starting at 500 Watts, then 300 then about 175 Watts just before it finishes.
If you have a home energy meter in your home, you can witness this process for yourself.
Ask me how I know !.
As others have said, you CAN charge and balance from your 7 kw wall box.
But NOT from a rapid unit.
When you are requesting a charge from your wall box, from any SOC up to 97 - 98% the car will permit the full 7 kw's.
At around 97 - 98% SOC the rate will reduce down from 7.0kw's down to 3.5 kw's until it then hits the 100% fully charged state.
The MG light in the grill will be displaying a soft glowing / pulsing light while this takes place..
Then when balancing process will commences, the MG light will switch to a soft constant / steady glow.
When the MG light goes out, the balancing process has completed and your wall box will automatically shut down with it's familiar heavy "Clunk" sound from the unit.
Remember, if your HV battery has been badly effected by the Buggy software, then it is likely it is going to take a while to recover and it will require a number of charge / balance processes to recover.Thank you for the advise lovrmyev I will put it on my 7kw pod point tomorrow after I run battery down 1 bar as you suggested.
What was the resolution from the dealer, what did they do to fix it? I have just had the same issue and is on my way back to the dealer any info would be appreciatedI have a choice of a courtesy through the AA but I want MG to supply one longer than 3 days, it's an utter joke, thanks for everyone to help to get this resolved, don't really get much from the dealers/MG UK
Don't know if this helps but my my had a similar problem it turned out to be the battery charger and the car battery shut down to protect the car, after the charger was fixed I had no more problem and mg did a update on the carHi all
My car has been in the dealer because of the below faults, the car was recovered by the AA and got to the MG dealer with no faults what so ever, they could start the car and run the car fine. Looking at this it tells me there are faults and now I cannot move the car, I've left the car to fully charge on a 7KWH charger and these errors have now come up when it reached full charge. Has anyone had any experience with this? The dealer said the car has no issues as the errors were gone when it reached the dealer. I don't have a clue what to do as they couldn't diagnose anything with the vehicle, they ever charged it to 100% with the MG pod point charger at MG and the technician took the car home to test the mileage.
MG have confirmed my car is fully updated with the latest BMS, I have tried multiple balance charges with no success of having the voltage of the battery improve any....
in the mean time I'm contact the finance provider to try get a break in the finance agreement as I'm sick and tired of this.
Any ideas.... I've run out and sick and tired of the car now???
Worthwhile speaking to your dealer I had the same issue caused by a faulty Rapid, they did a software update and have not had an issue since ?I had the error warnings for disconnected high volt battery (yellow, struck through), and malfunctioning low volt battery (red) after charging for 10 minutes at a high speed charger in the Calais Eurotunnel.
Per advice in the thread I disconnected the low voltage battery negative terminal for two minutes and reconnected and all seems good now.
Posting mostly in case helpful to others, but any other advice at this point? Should I see a dealer just in case? (I normally granny charge at home, which sounds from this thread is a good thing)
