MG4 Charging port lights stopped working
I hesitate to say this without checking, but on mine for quarters that are fully charged the green is solid and the quarter in progress slowly throbs. I'll check next time I charge.
That's what does happen ... the quadrant representing the current SoC state whilst charging will pulse.
The behaviour of the lights seems to vary depending on which car module updates people have.
Mine are white / light grey before communicating with the charger, bright blue when communicating and bright green when charging.
Just happened to me. Charging LEDs all off....
No problems fixing stuff on cars including simple fuse stems cleaning.
Says fuse box "behind the driver side knee trim panel"
Fuse boxes should be easily accessible to change fuses.
For the life of me I can't see it or see how to access it hidden behind some panel.
Those folks who've done this - what are the required steps?
The video is in #26 of this thread, top brown fuse
Missed it :)
Thanks - will try tomorrow...
Once you know how to access the fuse box it's not too bad - just need trim tool to easily remove cover.
Anyways. did not disconnect battery.
Simply removed fuse, used pencil rubber to clean the 3 fuse legs and re-inserted about 60 secs after removing.
Charging LEDs are back on again...
Personally, I think the cleaning is probably unnecessary, taking the fuse out almost certainly just does a number one fix on a subsystem the control's the lights - ie number one fix, turn it off and on again.
Glad it's sorted
Glad it's sorted
Tend to agree about no need to clean legs. Did it simply because I pulled the fuse and only takes 15 secs.
So it all does point to the software bug and powering-off of the LED circuit resets the relevant bit of software.
Sounds about right! I reset my non functioning charge port lights by briefly disconnecting the 12V battery.
Just search this board - this has been discussed many times. There's a fuse that can be pulled out and reinserted and that usually fixes the problem.
If you don't want to pull apart the trim to access the fuse then the same can be achieved by disconnecting the 12V battery for a minute then refitting - but you'd need to recalibrate the steering wheel and window motors sensors afterwards. (Easy to do).
How do you do this? I really appreciate your help.
Which specific point are you querying?
You use this to do a search - select This Forum from search area options.
    Votes: 933 77.6%
