MG4 Secret Menu Mode...
With 1100R33 that utility works fine. After entering the phone code below, I got this menu:
Code:
#*#4479*#*
Tapping 5 times in the bottom right corner gives a password prompt - entering the code from the utility gives this screen (i.e. 2 additional options). I didn't try pressing either of them - I was merely testing that the utility worked:
Don't stress, you can't break anything in that menu. It's the same one the dealers get to do updates and see version numbers.
You can't actually do any harm in there.
There is an extra level of engineering menu in there that we don't have access to yet.
If you tap the bottom right corner of the engineering screen 5 times, a password box pops up. We haven't cracked that one yet.
Not getting that menu. Trophy owner here
Details for the Trophy are posted elsewhere (maybe earlier in this thread) ... the recent info has related to the SE only.
If you export the log on a USB drive after a try with an incorrect password you con find the correct password in the logcat file.
Sorry for the late reply.
My MG4 was in the meantime at the garage and they made a SW update to R33.
Now the Password Generator works !
BTW, does somebody know how to disable by default the LKA (Lane-Keeping Assist) because it still does not work like it should, even its dangerous if its enabled.
As already said it's not possible but at least with R33 it's much quicker to turn off as it's now possible using the pull down menu from the home screen.
    Votes: 938 77.6%
    Votes: 179 14.8%
