NLMGSAN
- Dec 26, 2023
- Location
- Ede, NL
- MG4 Trophy ER
Wasn't the LKA update mandatory?
There will have been some car module updates for various things but it is not possible to tell as we have no access to the installed version numbers. Your garage should have a record of what was done.So is it the case that there have been no mandatory updates since last March?
Ok, I will give it a drive to see if the LKA has been updated. I was just going off the software version.There will have been some car module updates for various things but it is not possible to tell as we have no access to the installed version numbers. Your garage should have a record of what was done.
Possibly, although the infotainment IS easy to upgrade and can be done via USB so it is rather different to the car modules.I had mine serviced last week and they didn't update the infotainment software. I'm still on r24.
I wonder if they have stopped updating the infotainment software as there is a new "improved" version of the infotainment software coming out and they don't want to pay the dealers twice for doing the update.
It's booked in later this month to have the passenger door handle replaced and I've asked for them to check that all the software updates have been done at the recent service.Possibly, although the infotainment IS easy to upgrade and can be done via USB so it is rather different to the car modules.
It might be fear of you getting a problem with the upgraded version, so that might be either an MG or dealer decision.
I got R46, but not at service, in response to me reporting various minor issues - however I would say my dealer's attitude was "let's get you on all the latest software because that's likely to solve most of your problems".
That is wise. It took 3 visits in the end to get everything sorted after the CCU fix and updates.It's booked in later this month to have the passenger door handle replaced and I've asked for them to check that all the software updates have been done at the recent service.
To be honest I'm not overly bothered about the infotainment version. I don't use bluetooth and rarely Android Auto and don't want to swap one set of problems which don't bother me or I can work around for another set which I can't.
Do you mean less likely to give a false positive?
- AEB: I can't easily test it but apparently this is now less sensitive and likely to give a false positive.
Asking them to do all software updates isn't likely to get you onto a newer version of the Infotainment.It's booked in later this month to have the passenger door handle replaced and I've asked for them to check that all the software updates have been done at the recent service.
Yes. Amended.Do you mean less likely to give a false positive?
I'd like to understand why the module firmware updates are proving so troublesome. It's not rocket science. Consumer electronics software upgrades have been common for years (mobile phones, Smart TV's, etc). Do MG have this problem on their other vehicle platforms? Are the dealers' problems the result of an unreliable, poorly-implemented CANBUS communication protocol on the MG4?
There are far more than a dozen modules in the MG4, especially on the higher spec versions (which get more problems).@tsedge - But surely they would design a Support and Maintenance regime for the MG4 around the dozen or so modules actually in the MG4, so it's not quite the problem that you suggest. As you say, we're almost 2 years into the product and there is apparently little or no recognition of any faults, let alone fixes for them.
I was trying to find a list of the modules recently. Do you know where I can find one (and what they do) ?There are far more than a dozen modules in the MG4, especially on the higher spec versions (which get more problems).
Thanks very much.R33 is associated with the Trophy spec.
I don't have one - maybe in the workshopI was trying to find a list of the modules recently. Do you know where I can find one (and what they do) ?
