Retsiba
Well done Briggie, your co-ordination is on point and well appreciated.Done on a new thread and added to hints and tips
I believe LKA has its own module. Someone reported getting their dealer to do an update on that module and it improved it a lot.R13 is the Infotainment as your say (I have the same) but certain features are part of other modules/controllers which will have their own, separate software versions (which we can't see).
I've not experienced anything bad (so far) with LKA.
Can you try it?There's a video on YouTube (linked here somewhere) that explains how to access the Engineer menu ... it needs a PIN but nobody knows what it is. (I don't know if anyone has tried it yet and tried the last 6 digits of their VIN to see if it works).
I found the LKA was a little less sensitive after the update, but it will still try to take any slip road you come across with no warning.I had all available vehicle updates on Tuesday apparently but have no way of verifying unless anybody works out how to get into the service menu.
The driver attention alert hasn't changed and my wife said the LKA is still terrifying though so it's turned off again. I'll give it some more testing over the next couple of weeks to see if I notice any improvements.
That relies on me remembering. ??Can you try it?
That relies on me remembering. ???
just went out to try it ... I can't even get to the PIN entry stage. Then again my Settings/System menu doesn't have the top item (Actualizar - To update) shown in the videos (which uses a Trophy/Luxury) ... my top item (in the SE) is the Infotainment version. I've tried tapping that one and also the MCU one but no PIN entry pops up.
This one shows that it is a 6-digit PIN though, so the last 6 of the VIN might be a reasonable guess (if you can get that far):
Last 6 of vin in reverse order ?It's not the last 6 digits of the vin ?
Any other suggestions, my guess is MG have something on their system
We know that the EU version numbers can vary from UK (someone had R08), looks like you are in Iceland?EU Luxury, delivered today. R33
I’ve added this to the sheet with the versions.EU Luxury, delivered today. R33
Two R08s in Germany.We know that the EU version numbers can vary from UK (someone had R08), looks like you are in Iceland?
Yes ?We know that the EU version numbers can vary from UK (someone had R08), looks like you are in Iceland?
