BillyWhizz
i keep a eye on it thanks for the info
Thanks, under the "Maintenance" section, I was looking in the "Charging requirements" section, which seemed a more logical place to find it.On page 235 under maintenance: High Voltage Battery Pack...
Sounds a bit more of a faff than looking at the smart meter monitor.Power up the car and look at the power flow screen. I recommend you turn off the AC etc as this uses lots of power.
You'll see how much power is flowing in. Before I reached 100%, I had a reading of about -11 Amps (I only have access to an on-street 5kW lamppost charger).
Once mine reached 100% and it started balancing, it fluctuated between 1 and 5-ish Amps.
When balancing had finished it went to zero or even a small positive number.
It was always something that happened on the Mitsubishi Outlander....always did cell balancing as part of the AC charge cycle, obviously didn't do it on the DC cycle. It's good practice for multi-cell packs.What do you make, Petriix, of the advice in the manual to do the balance charge once a month? Must admit, it was never something I did with the Leaf I had before, but in the MG community it seems to be de rigeur. I've just done it a second time, but a full charge at the moment is lasting me the best part of the month, whereas with the Leaf I'd just charge a bit here and a bit there, as and when...
