peterclose
how do you use this?
Hi. Could you send me the file too please. Thank youIt probably just needs DAB files installing
I have them if you need them
its working with EHS?thanks got it working again , not sure its the same file as before but at least it works
It’s works, thank you guys a lotits working with EHS?
I have this same problem too. Are you able to send me the DAB files also.No problem
Saves the dealer doing it
Check back a few posts, #129 or #94I have this same problem too. Are you able to send me the DAB files also.
I’ve just had the radio module changed on my 3 month old ZS EV. It was only about a week from ordering to fitting at the dealership.Hi guys my long range mg5 went into dealers today as it was showing radio module initialising when they phoned me up they confirmed that it needed a replacementhol module they said they would order the part but could not give me an eta. Does anyone who’s had this done know the waiting time for the part.
Hey, can you send me those files for mg Zs EV mine is 2019 plate, I need the main unit and radio updates if you have them that would be so helpful ?I can get zs ev2019
Hi, could you send me the files please ? Thank you so much ?Thanks my radio works perfectly now .
As an update following the radio module replacement, radio worked for a week before Christmas and has now stopped working again. This is causing the 12 volt battery to discharge again. Booked back into the dealership for a 5th time!?I’ve just had the radio module changed on my 3 month old ZS EV. It was only about a week from ordering to fitting at the dealership.
HiGuys I've managed to update the radio and it works however I get series of errors on my dashboard after the update, my car is out of warranty is there a software update for MG ZS EV 2019 that I can use and update the car ?
I had this today when I was trying to update. It's because you've got the error so there is no dab version shown. If you disconnect the 12V battery and then reconnect, the error will clear and the current dab version will be shown. You can then click the update button to apply the new fileMorning all, "Radio Module Disconnected" came up for us the other day, but it's still playing the last station selected.
I've tried to update with the .bin file - but the bar doesn't move (Fat32, tried 2 sticks). Any ideas?
There are many links to the file in this thread, just scroll backI have the same problem but Mg Zs 2022 1.0t automatic. Can send me the file for DAB update thanks
On my 5 they're usually gone after driving a few metres, I guess just enough for various sensors to start recording data.Hi
You may have more success asking for updates under the MG ZS forum, but from my experience on an MG5 these errors can appear after a 12V battery disconnect and usually disappear after driving for a couple of miles…
