unbornidentity
- Feb 3, 2024
- Location
- Gloucestershire
- MG4 SE SR
Haha, can’t deny it!And a little bit smug.![]()
So has yours still got the gloss front lower section or the matte version that seems to be coming through on later builds?Looks like I’ve got a pre-factory fix one after all that. That MG VIN checker said September 2024 but the certificate of conformity in the glovebox says 07/03/2024. It still got the strong new car smell, so surprised it a year old.
Looks like old stock lying around being the real reason it was so cheap might be true.
It’s going in for the damper in just under two weeks and if that doesn’t work I’ll tell them I want whatever the fix is at the factory done to it or probably look to reject it.
Very tempting to put up with it though as I don’t do much motorway driving.
No it’s got the matte trim and all the software seems up to date. LKA actually seems to work, ACC is actually useable. I suppose the dealership might have actually updated everything.So has yours still got the gloss front lower section or the matte version that seems to be coming through on later builds?
Bad luck on the vibes - it seems to vary so much from car to car. 15k miles in and oddly ours is the best it has been in terms of the characteristic’.
Push dealer for new set of tyres (we did and got Michelins) - the standard tyres are terrible in every respect so even if it doesn’t help with the vibes, it’s a major upgrade.
Build date in MM/DD/YYYY format so yours is July 24.Looks like I’ve got a pre-factory fix one after all that. That MG VIN checker said September 2024 but the certificate of conformity in the glovebox says 07/03/2024. It still got the strong new car smell, so surprised it a year old.
You have made me go back and check my CofC. My car was indeed built on the same date as yours 07/03/2024Looks like I’ve got a pre-factory fix one after all that. That MG VIN checker said September 2024 but the certificate of conformity in the glovebox says 07/03/2024. It still got the strong new car smell, so surprised it a year old.
Whilst I regularly scold my cat for food theft , the typical accelerative cat has been scalded!But plant that accelerator pedal and it’s off like a scolded cat. The acceleration is mind boggling![]()
Strange isn’t. I was wondering if yours would be the same date.You have made me go back and check my CofC. My car was indeed built on the same date as yours 07/03/2024
Both of ours are 07/03/2024What’s the manufacturing date - normally found on A4 sheet in glove box or if leased/PCP, then on a tag attached to rear left/underside of the parcel shelf?
Oh they use the US date format then? I thought I saw on another thread it was in the European format.And just to reiterate ... that's July 3rd 2024 not 7th March 2024.![]()
They use a variety of formats on the Certificate of Conformity, but I know for sure that the build date is US format as mine is 08-28-2022Oh they use the US date format then? I thought I saw on another thread it was in the European format.
