Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
Yes, it is doable. Thanks to you lot, I went out and gave it a preliminary try. You do need something to raise the foot end of the lilo, at least in the SE. A single inflatable cushion wasn't enough, but an actual pillow was fine.
I tried again with two inflatable cushions, and that worked too.
I'm sorry neither picture shows the foot end, I'll go back out and take another showing that.
The lilo (actual cost 13 euros, the price sticker was still on it) seems quite comfortable, although it is not as long as it claims to be on the packet. (Says 185 cm, in your dreams.) I do have an actual airbed which will take up more space but might be more comfortable, which I will try on another occasion.
The small suitcase was just right for height to support the pillow end of the lilo, although I didn't get it central due to the raised part of the floor getting in the way a bit. There might be a way round this. I removed the passenger head rest on that side to get it in.
For a preliminary trial, this worked pretty well.
Here's the picture of the foot end.
There is a reasonable amount of vertical space, I don't think that's going to be a problem. I think you would be able to build a framework to raise the floor and it would still work.
The lilo is in fact about 166 cm by 60 cm, well short of the 188 cm by 71 cm advertised on the packaging. I will try my airbed another time as that may work better, but the lilo is OK and would work.
I did notice that the car switched itself off while I was in here typing my previous post. It stayed on while I was working in it, and in fact got too warm and I had to turn down the temperature on the HVAC. But while I was away, it turned off. I don't know what governs this, or how the other member got it to stay on. Thoughts appreciated.
