Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
That's the bucket.
Portable induction hob to use with your VtL adaptor, available from £45 and cheaper than Calor Gas..I've been trying to think what the checklist should be of things to take with me. Thoughts appreciated.
Airbed or lilo
Sleeping bag
Something to raise the foot end of the airbed
Water
Collapsible bucket
Kettle (VtL adaptor needed)
Washing kit and towel
Something in the way of food for an evening snack and breakfast
Folding garden chair and picnic table
What have I forgotten?
You’ve not mentioned window blinds I don’t think. When I was travelling around I hung towels on bungee cords over the back doors and the back of the seats in my van. Most times however i just pitched a wee tent beside the van as I usually carried a fair bunch of spare parts, plumbing fittings and tools. On occasion I carried complete hot water cylinders with me for replacement if required. A tow bar mounted carry frame was also used for those sometimes :-I absolutely think it's the key that is the key, so to speak. There is obviously a standby timer that activates when the key is not present, as I've seen it do that before. I can experiment with these things, and also with locking it from the inside.
I was under a misapprehension about the lilo, because I believed the dimensions on the packet. I thought it was close to the size of the airbed so there would be little difference between them other than in the thickness of the "mattress" but not so. I think the airbed being larger might work better because it would fit in the available space without tending to move around so much. If it's not raining tomorrow I might give it a try.
Another advantage of the airbed may be ease of inflation. Of course it takes more to inflate it than the lilo, but it has a wider opening that inflates quite easily using a hair-dryer. With VtL available, that should be possible. Of course there are pumps available to inflate lilos, but I don't happen to have one.
I am not necessarily planning to sleep in the car, as I like my home comforts, but I have in the past been close to needing to do so because there was no accommodation available, and once as a teenager actually had to do it (in a saloon car with three other people - my parents and an aunt - so we all had to sit in our seats) and it was hideous in that situation. I want to be prepared so that I can do it in comfort if need be.
Airbed or lilo
Sleeping bag
Water
Collapsible bucket
I have occasionally thought about getting some sort of frame made to raise the boot floor, for occasions like this, so if anyone has any idea about that for the SE I'd be interested to hear about it.
Have you tried putting it into the ready state?
Sit in the passenger seat (Parking brake will already be applied)But as soon as you hit the parking brake, it's out of Ready.
I did think about blinds, although I'm not sure how practical this is.
If I can't figure out how to make the HVAC stay on all night, all bets are off anyway.
Does that still leave you with the problem of the DRLs?Sit in the passenger seat (Parking brake will already be applied)
Lean on the driver's seat to turn the car on
Use a stick (or lean down if you're flexible enough) and press the brake pedal to go into READY state (parking brake will remain on)
Exit the car via that passenger door and get into the back of the car (READY state should remain)
Seems like they might do...What we need is somebody to build us something like this for the MG4. TERAGLIDE | Tesla Model Y Trunk Bed | New Zealand-Crafted
2) Has been checked. If you press Lock Doors on Remote Key fob, whilst in the car (with the key fob), it will arm the car. Trying to get out of the car by using the manual door handles will set off the alarmHave you tried this? I rather got the feeling that it wouldn't lock if it thought the key was inside. (I can't check as I'm away at the moment).
Having said that, detecting the key being inside or out seems magic to me and I'm not sure I'd trust it fully.
I believe that the eZS app can turn off the Daylight Running Lights. It's designed for the ZS, and I believe that it works for the MG5, it may work for the MG4. Android only.means that the front small lights (DRLs?) has to be on,...
Any hints or suggestions?
