T1 Terry
- Feb 7, 2024
- Location
- Mannum South Australia
- MG4 SE SR
Woken up this morning with the MG beeping its horn in a regular pattern. Turns out that the MG supplied granny charger has died after 2 weeks use
It had been plugged in for 2 days, the screen said it was charging, but it was still at the same 74% it was at 2 days ago.
Dug out the Aussie made unit that can charge from 10 amps or 15 amps, charging commenced and I, quite by accident, discovered that a double tap on the charging section on the home screen opened up a page dedicated to charging. This also showed it was charging, but zero going into the battery .....
Messing around in there, I found a charging limit, tried the 6 amps, still nothing, 13 amps ..... charging at 300w .... Back to the Aussie unit, it said it was putting in 2kw .... WTF
Turned off the air con, bingo, now it read 1.3kw .... so the air con uses 1kw
but where was the other 700w between the Aussie charger adapter that read 2kw and the screen reporting 1.3kw ...... is this normal, or do I have a problem already .... I was hoping for a honeymoon period at tad longer than 2 weeks ......
