AdamMGEV
- Feb 15, 2021
- Location
- Cheshire
- MG4 Trophy LR
This is what mine says, I'm getting the valve on the 0.0 tyre fixed this week
It has taken a while hasn’t it? If I remember correctly you mentioned this a while back. Was that getting parts?
Ye over 6 weeks ago. Not been bothered as the tyre is fine but not sure why its taken that longIt has taken a while hasn’t it? If I remember correctly you mentioned this a while back. Was that getting parts?
In that case, I'd be checking if all the tyres are the same size. ?I am going to make a guess that the TPMS system on the MG4 is very similar to the other MG EV’s.
A lot of TPMS systems work by each wheel constantly cross checking the speed differential between each wheel ? and then triggers an alert if one wheel rotation conflicts with the preset settings.
According to the spec sheet, it should have TPMS monitoring.Hope there is one on the SE? ?
It’s on the iSMART app when you press the ‘vehicle status’ button.Hi Everyone,
How do I activate the TPMS display/info please?
MG4 SE
Mark
A lot of TPMS systems work by each wheel constantly cross checking the speed differential between each wheel ? and then triggers an alert if one wheel rotation conflicts with the preset settings, I believe.
A tyre that has a puncture will be traveling at a different rotational speed as the wheels which are reporting correctly.
On VAG group cars this is done via the ABS system, via a speed ring on each wheel hub.
If the recommend tyre pressure on a VAG group car was 36 PSI - but the owner had set ALL the pressures to a identical 40 PSI then reset the TPMS it would be happy, because they are all identical.
I my experience of the VAG & BMW system, are that they trigger when ONE wheel losses more than about 2 PSI over the other wheels, regardless of pressure they where set at.
But the MG system is different as it has a sensor built onto back of each of the tyre inflation valves on each wheel, powered by a coin cell battery in the sensor.
I have found that the MG system read outs do fluctuate around a fair bit, even on the same day !.
If the car is parked with one side of the car in direct sun light, the pressure read out in those two tyres will be higher.
As you would expect of course, but the system must have the capacity to adopt to this fluctuation, is what I am saying.
We had our first TPMS warning flag up about two weeks ago, in our ZS EV facelift.
Totally out of the blue and for no apparent reason ?.
One wheel triggered, then after a couple of minutes the other wheels started to trigger warningsone after the other !.
When I checked ALL of the tyre pressures, the one that first triggered was about 2 PSI down on the the other three, to be fair.
I reset ALL of the tyres and double checked them with TWO different tyre pressures gauges all reading bang on 41 PSI.
When I booted up the car, all four TPMS sensors where still triggering the alarm.
I was just about to set off for a drive ( to recalibrate the sensors ) but then all the warninglights went out and the bonging stopped.
The sensors has taken about 20 seconds to talk to the car and was happy with what it had seen.
The car had NOT even moved at this point !.
I know the pressures are bang on, but I did keep checking what the car was reporting.
Very close, but the was a sight difference between the pressures reported by the car.
We have not received any further TPMS warnings to-date.
Today the weather is extremely wet and a bit chilly.
I have just checked and the App reports that all pressures are absolutely identical, strangely enough.
The VAG system works via the ABS system and has no TPMS battery powered sensors in each wheel.The system you describe that measures wheel rotation is a basic tyre pressure WARNING system
Agree. My old (2012) Golf had a warning system; my Insignia (and this MG4) are monitoring systems.Two distinctly separate systems.
One is a very basic warning that a tyre is softer than the rest
One actually tells you how much air is in each tyre at any given moment.
Are you saying that this VAG system gives you a measure of tyre pressure (via the rotation/ABS)? If yes, HOW? Yes, it knows if one tyre is different to the others, but it can't know what the actual pressure is.The VAG system works via the ABS system and has no TPMS battery powered sensors in each wheel.
It measures and compares the rotational speed across all four wheels in milliseconds and feeds that info back to the module and then back to the driver if it detects that one wheel is turning slower than the three other wheels due to a possible puncture.
It is good a detecting a fault, when there is a 4psi differential in pressure in that suspected tyre.
When a wheel rotation has taken place, there is no requirement for a relearn process.
TPMS system on the ZS EV Gen1 will require each sensor to be recoded to the new position on the car.
The improved system on the Gen2 model does have a relearn facility and no recoding is required to each sensor.
BMW uses a similar system as VAG via the ABS system.
TPMS is a mandatory requirement on all new vehicles since November 2014.Hope there is one on the SE? ?
Yes, that is how the VAG system works but as you've already said, the MG system is a different type - each sensor has a battery as bowfer has described.The VAG system works via the ABS system and has no TPMS battery powered sensors in each wheel.
No, it doesn't, it just tells you that "a tyre" has low pressure. (That's my experience across 3 different VAG vehicles in recent years).Are you saying that this VAG system gives you a measure of tyre pressure (via the rotation/ABS)? If yes, HOW? Yes, it knows if one tyre is different to the others, but it can't know what the actual pressure is.
Yes I am aware that the MG sensors have a coin cell battery powering each sensor in each wheel, it was in the first line of my post 31 see above.Yes, that is how the VAG system works but as you've already said, the MG system is a different type - each sensor has a battery as bowfer has described.
