Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
You've got R33 though. What did it show when you had R13?
I can't get the right hand nozzle adjusted right.It doesn't seem to go through the wash fluid very fast with that fine spray, but I'm finding mine is missing bits of the windscreen. The right-hand nozzle seems to be spraying too far to the right.
It does only need the slightest adjustment, what are you using? I pinched one of my wifes small sewing needles and adjust with that. She has never noticed its gone! Thats because I do all the sewing?I can't get the right hand nozzle adjusted right.
At first it was hitting the wiper arm, then it was going over the roof, now the spray hits the screen when stationary but blows over the top when moving.![]()
I can't remember, but I thought it was the same 0.5 ?You've got R33 though. What did it show when you had R13?
The manual says use a small flat blade screwdriver, but that only works for up and down, so I'm using a reset pin that I got with my phone that fits snugly in the hole.It does only need the slightest adjustment, what are you using? I pinched one of my wifes small sewing needles and adjust with that. She has never noticed its gone! Thats because I do all the sewing?
On this car mine seem to be ok, although I have used the pin on previous cars.The manual says use a small flat blade screwdriver, but that only works for up and down, so I'm using a reset pin that I got with my phone that fits snugly in the hole.
I tried up, down and sideways movements but none of the positions seems to work very well. The left hand one isn't bad as it's situated further across from the wiper blade/arm and misses it nicely.
I don't like the fact that it's fine spray instead of a jet.
Top Tip.I can't get the right hand nozzle adjusted right.
So that makes my sewing needle redundant then! As I said mine appear to be ok, but will keep in mind your tip ?Whatever happened to the little silver ball you stuck a pin in ?
I thought of that but decided to lift the bonnet to get at them instead.Top Tip.
Put your wipers into the service position.
Makes the adjustment easier.
Notice I said easier?
They are without doubt the most awkward to adjust I've ever come across.
Might just be my old eyes and reading glasses.
Whatever.
It is a faff to get them where you want.
I've bought a selection of aftermarket nozzles off Ali express to try when the warmer weather comes and I work out how to get the originals off.
Yes. I've used Prestone SW for years. Not had any freezing screen wash in that time.Another vote for Prestone. I buy a big 5 litre container of it from Costco. In winter I use a 4:1 ratio, and summer 10:1. Doesn't get cold enough here to need to use it neat.
