Found ZS Service Book Download
On the Gen 1 model, the second service was pretty much the same content as the first service, but they replaced the cabin filter I seem to remember ?.
Some owners had their brake fluid replaced also, but not us.
Here is the 2nd year service pan for the MY 21 in Australia, at MG Precise Price Servicing | MG Motor Australia
SERVICE INCLUDES:​
  • Pollen filter
  • Brake fluid Change
  • Check vehicle for any outstanding Campaigns
  • Reset service indicator
  • Carry out road test of vehicle to test for driveability abnormalities
  • Check vehicle systems operation via VDS
  • Check status of manual service switch to ensure reliable mounting and clean dust on surface
  • check the appearance of the vent valve for damage, and check the marking for fitting to see if moved
  • Check drive motor mounting bracket
  • Check the status of brake vacuum booster and hose
  • Check the appearance high/low voltage connectors to confirm if surface has any damage
  • Check the high voltage harness for mutual interference, wear or damage
  • Check the appearance of high voltage battery housing for crack or deformation ( including the bracket )
  • Check connection and status of 12V battery
  • Check the appearance of high voltage battery pack grounding wire and replace it as nessecary
  • Inspect condition of cooling system, coolant level, check for leaks & condition of hoses
  • Inspect operation of windscreen washer system and top up fluid
  • Inspect condition of wiper blades
  • Inspect Brake disc brake pad condition
  • Carry out annual vehicle body/cosmetic inspection
  • Inspect Seat belt operation
  • Inspect Headlamp Alignment
  • Inspect front suspension, tie rod ends, boot seals for wear and damage
  • Inspect underbody for damage to protection panels, fuel and brake lines
  • Inspect Wheels and Tyre conditions
  • Check condition of battery using approved MG battery tester and recharge if required.
  • Check operation of lamps, horns , and system warning indicators
  • Check handbrake operation and adjust if necessary
  • Torque Wheel Nuts
  • Lubricate and check tightness of hinges and check straps
  • Lubricate Bonnet Lock and Safety Catch
  • Fit next service sticker to windscreen and stamp and complete filling out the service logbook.
