MrRee83
Issues I have come across, if anyone can help? list below:
- pressing the passenger window switch (driver side). I press it all the way down and let go, it auto opens fully (good). Select it up and it does nothing, select it again and it doesn't auto close back up. Just moves depending on how long you select it up.
- Can't control music volume or track selection using the left analogue stick on the steering wheel, it worked on volume for a little bit then stopped all together.
- When using the Power Off button, it activates a timer and turns off the music, can this be changed?
- Right Star button, takes ages to activate what you need (like AC settings), is this common?
If I have any other issues or suggestions I will post them up, but if anyone has answers please reply
