boira
- Aug 13, 2023
- Location
- Lleida (Catalonia)
- ZS EV Luxury
Those authentication problems are most likely bugs that will be sorted out soon... so let's wait.
I had that problem, shut down the phone and restart seemed to work for meTried that too - same result.
Avoid unbinding to the car if you can !.I had the old APP, no problems, working grand.
I updated to the new APP and the app is saying that I cant bind to my car because my car is already binded (presumably to the old app somewhere). So how do I unbind from old app and rebind with new one >?
ThanksAvoid unbinding to the car if you can !.
When you are prompted to sign into the new App, use either the e.mail or phone number that you used to create the original account.
Only use one of these if you did so, to create the original account.
I ONLY used my phone number to create my account.
I have not had any problem signing into the new App and it appears to work okay.
But after about 30 minutes to 1 hour it will not allow me to access the account, unless I enter my password every time, which is frustrating to say the least.
Just put the email address in the phone number fieldThanks
But the App doesnt let me login using my Email account (that was the original account!) , it only allows me to put in a mobile number
When I logged in using my mobile I must of setup a new account as theres nothing on it and it wont let me bind to my car!
Thank you so much! Crisis averted!Just put the email address in the phone number field
It does let you log in via email- that’s what It did (albeit the design doesn’t make it obvious)Thanks
I’m assuming that turning on the Air Conditioner is the same as Pre-heat on the old version and this always cleared the windows very quickly on old version.Hi all,
the title pretty much says it all, ever since I updated to version 2.0.1, the defrosting "Front Window" option does not work as intended.
It does start the fan, but it doesn't heat which pretty much makes this option usless in winter.
When I start the "Front Window" option, then turn on the infotainment in the car, it says that temperature is set to "Lo". This definitely was not the case before!
Also, it would be great if this option really did a proper defrosting meaning also starting rear window and side mirror heaters, but I guess that is wishful thinking.
Did anybody else notice this behaviour?
I have the facelift LR trophy model BTW.
I did that, but then it turns off the Front Window thingy and turns on the "regular" AC fan.You will probably need to set the desired temperature in the air conditioning section. This temp should then apply to the window defrost mode.
Use the A/C blowing to defrost car, not front window
Yes, I'll use the A/C blowing as a workaround.I’m assuming that turning on the Air Conditioner is the same as Pre-heat on the old version and this always cleared the windows very quickly on old version.
