MG4 EV SE Reversing camera 2024 UK
I wonder if early SE models have the neccesery pinouts on the infotainment to integrate OEM camera?
Anyone done any research on that front? We know Trohpy software works, so there shouldn't be much issues on that front.
I got a non-official camera added to our SE. Bought off AliExpress.
No, but it uses the video input on the centre display:
Please get the AHD version then, the normal 480p is pretty crappy by the looks of it.
Too bad there's still no solution to integrade OEM camera natively.
Someone with a 2024+ SE could check part numbers and wiring on their infotainment, if it matchs that of early cars. I would be surprised if SAIC cut HW functionality out of their infotainemnt.
The results from that camera look excellent. But installation looks to be a nightmare. I am also vary wary of installing something that needs holes drilled when it is quite likely I'll be handing the car back at the end of PCP; if I was likely to part-ex instead it wouldn't matter.
Do you know how the camera gets installed? Doesn't seem like it would fit nicely, looking at the camera.
I think there is a small hole drilled in the plastic at the back, no interference with any metal.
The device behind the glove box is plug and play and can be removed if required. There are wires run through the car - not sure how easy it would be to take those out.
Of course, getting a professional to remove everything would be expensive.
However, given that the feature is a bonus in the car I don't see why anyone would want it removed.
    Votes: 931 77.6%
