AB71
Really wow ?No front parking sensors on Trophy either, only rear.
Site guru I’ve just been out and parked it up going further forward than normally would and you’re so correct ? thanks for that
I read the manual yday and that three flashes is auto installed as a safety featyreWent in for updates on phase 1 Exclusive/Trophy due to a list of complaints.
Now on R46, with the refreshed air con screen etc.
There was a list of 6/7 ECUs with updates carried out.
Since getting it the day/night switching has much improved.
Screen still defaults to day mode when starting at night though, still have to flick headlights to fix.
Tyre pressure is now not giving an alert when slightly below pressure in cold weather.
Previously the rear would go at 2.4 BAR and even though the pressure would return to 2.6 after a short drive the error would remain. Now there is no warning at 2.4. I don't know if they lowered the threshold or it now accounts for the temperature.
Apparently there was a fix for the auto headlights too.
AC is still about 4 degrees off.
Rear collision assist (three quick flashes of indicators) still occurs occasionally when cars go past in an adjacent lane.
It'll take week or two to know how Bluetooth is.
No one-pedal driving sadly.
If the Bluetooth remains connected I'll be happy.
I also read that a slight trill or noise will come if a passer-by pedestrian gets too
Close to warn them? Did we know have we heard about this?
So you’re at R20 but someone said latest is R33 which was is it plz folksI think you will find SE models and Trophy models have different software my brand new MG4 SE Standard Range is running R20 software and it the latest version for the SE apparently. So I can then assume the latest Trophy software is R46. Only thing ive noticed with my SR is the intermittent operation of the one pedal driving even when the battery is at 50% hopefully this can be sorted with the next version of the SE software. Not overly bothered with it at the moment as I assume that will be the official answer if I was to contact MG.
Rob
P.s currently doing well after a week of ownership current Miles per KW Hour 4.4 (11 degrees C)
Has anyone with the SE SR first phase without rear wiper etc successfully had an update and now have Opd?
