An update, on my previous post.
Since the update to PD052, I’ve learnt a lot, and can now say that the car is more responsive, and a pleasure to drive.
My initial perception was that there were many instances when higher rpms occurred, and this appeared to be negative.
However having accepted that the primary benefit of PD052, is to prevent situations where the dangerous ‘lack of power scenario’ occurs, by ensuring that the traction battery is never depleted. There has to be a trade off, and this has resulted in my altering the way I drive.
Not only has this resulted in a more relaxed driving experience, but there has also been a noticeable increase in mpg. The overall mpg record was deleted, when the update was applied. Over a couple of hundred miles, it’s now in excess of 62 mpg.
I appreciate that heating is no longer required, however it’s been replaced by my use of the air-con.
I also use regeneration level 3, which, provides almost one peddle driving, just a dab of the brakes to come to a halt is required, and then the auto-hold operates and releases as soon as I touch the accelerator pedal.
Oh, and the sun is shining
