Brettus
- Mar 11, 2023
- Solutions
- 1
- Location
- Chester
- MG4 XPOWER
FTFY ?(Noteverythingmuch is covered by the 7 year warranty)![]()
I read that the Xpower ride height is supposedly higher than the lesser powered MG4, although I’m not sure by how much? So I think it’s probably more a 20-25mm drop compared to a Trophy?It wouldn't be "slammed" 30mm is not to bad at all. And there is quite a big arch gap on the X Power. ??
Because it definitely looks better. Handles better, (supposedly) lower centre of gravity, less body roll, and all that. And finally coz we can. ??But... Why?
A common mistake with suspension upgrades are not matching the spring rates with the dampning and rebound of the shocks and struts. Also people don't loosen and re tighten all the suspension components with rubber bushings with the weight on wheels resulting in pre load on them which contributes to a bouncy ride!While lowering will improve the look, more often than not its detrimental to ride quality. Been there got the t shirt, but each of us can do whatever we want. In the meantime later I will be going on my first blast of the new year ?
Lowering springs are developed to work with the cars standard shocks, no need to change the shocks at all, unless you particularly want to. One thing I do, do though is get the tracking done etc. Me personally always go to Demon Tweeks in Wrexham, who supply and fit them, and do the necessary checks and test drive it before they'll let the car go. And I've never had any problems at all. ??A common mistake with suspension upgrades are not matching the spring rates with the dampning and rebound of the shocks and struts. Also people don't loosen and re tighten all the suspension components with rubber bushings with the weight on wheels resulting in pre load on them which contributes to a bouncy ride!
I think that's rubbish (probably invented by a dealer to get more cash), the VW radar on the Golf is quite high up, dropping it a few centimeters will make b*gger all difference that I can see. Certainly far less than putting a load in the back of the car!if anything like VW Golfs this may also include the radar, camera etc.... which used to require recalibration by VW at £200 a pop to remain covered after suspension changes IIRC.
Agreed, wouldn't go more than 30mm drop with just springs. And never even crossed my mind about you trying to initiate a confrontation. It's all about opinions, and that's great. ??I'm definitely not part of the fussy pedantic gang but what you're saying isn't 100% correct, please don't think I'm trying to initiate a confrontation. Most mild drop springs (30mm or less) will indeed be fine with your OEM struts and shocks
It's not quite that simple though as changing/lowering the springs will require a subsequent full wheel alignment to check camber and toe etc.. This is what can also affect the calibration of the Adaptive Cruise Control etc. There's plenty of threads out there about it (admittedy not MG ones though?).I think that's rubbish (probably invented by a dealer to get more cash), the VW radar on the Golf is quite high up, dropping it a few centimeters will make b*gger all difference that I can see. Certainly far less than putting a load in the back of the car!
Not convinced. If a four-wheel alignment makes the car crab enough to throw out the radar alignment, then something is seriously wrong, and I wouldn't be using that garage again.It's not quite that simple though as changing/lowering the springs will require a subsequent full wheel alignment to check camber and toe etc.. This is what can also affect the calibration of the Adaptive Cruise Control etc. There's plenty of threads out there about it (admittedy not MG ones though?).
