NLMGSAN
- Dec 26, 2023
- Location
- Ede, NL
- MG4 Trophy ER
Interesting. Across the pond they don't seem to have any knowledge of it.
Just curious - which dealership was that?Just back from my local dealer following some issues with all the safety features (forward collision, lane keep. AEB,speed limit recognition and ACC all unavailable….) and they said they got a message from MG yesterday in relation to the Which article. They are in the process of finalising an update to the software and when ready all the dealers will be asked to contact all MG4 owners to schedule in the update.
Let’s see if it happens that way!
Arnold Clark in SunderlandJust curious - which dealership was that?
Stupid it sets it to the most aggressive mode though. 1 I could understand but 3... just don't get why.Regen always defaults to 3. Same as drive mode always defaults to Normal, and LKA and other assist systems default to On. The MG4 doesn't support driver profiles, so the defaults are deliberate because the next driver may not be the same as the previous driver.![]()
Or even one pedal driving in the newer modelsI wouldn't want to use anything other than 3 unless I was going on the motorway, why would you not want to get as much charge back as possible?
Or Adaptive. It is slightly milder than 3.Or even one pedal driving in the newer models
To me feels way more aggressive than standard engine breaking you get in a manual car and no doubt just personal preference. Coming from driving an Ioniq for 3 years which had pedals to adjust the regen I hardly ever ran in the highest.I wouldn't want to use anything other than 3 unless I was going on the motorway, why would you not want to get as much charge back as possible?
Yeah I tend to move from 3 to adapative via a shortcut button on the steering wheel. Occasionally I've seen this shortcut button forget it had anything set. Will have to see if that happens after my update.Or Adaptive. It is slightly milder than 3.
Btw, I have placed regen under the button. So changing it is no problem at all. I use that button regularly, switching between 3 in town if OPD is off, and adapative on the highway.
I like OPD very much. Very relaxed. But I must remind myself that at higher speeds you still need to use the brakes from time to time. I deactivate OPD if ACC is active. I could use a button for OPD though...
Then you need an update. There is a fix for this.Yeah I tend to move from 3 to adapative via a shortcut button on the steering wheel. Occasionally I've seen this shortcut button forget it had anything set. Will have to see if that happens after my update.
I only tried ODP once in this car and wasn't a fan. Need to give it another go really.
Almost 2 years in with the same car, I find regen 3 perfectly fine.Regen always defaults to 3. Same as drive mode always defaults to Normal, and LKA and other assist systems default to On. The MG4 doesn't support driver profiles, so the defaults are deliberate because the next driver may not be the same as the previous driver.![]()
The most efficient regen is none at all, as regen is not 100% effective ie it loses some energy with friction, heat etc. hence I use the mildest setting for maximum efficiency. ie youre getting 70% back but having to put in 100% to get going again, thus losing 30%.I wouldn't want to use anything other than 3 unless I was going on the motorway, why would you not want to get as much charge back as possible?
You only slow down to the necessary speed for the conditions/event. Makes no difference, the end speed will be the same, regen or no regen except using regen will generate a pay back in energy terms, without regen it won't. Just because you use regen, it doesn't mean you slowing down to a lower speed than without as that's just bad driving and not adapting your driving to accomodate regen.Think about it, youre slowing down more so have to accelerate more, unless youre coming to a full stop.
A good example is when on adaptive cruise control.. my mg4 tends to rush up to the car in front then slams quite harsh regen on, even with different closeness settings.. much better to knock the speed back a little and be gentle about it. Smooth driving better than stop/ start..Y
True. It is far from 'efficiently adaptive'. But that's not because of regen. It also happens if regen is low. It is an error of the ACC, not of regen.A good example is when on adaptive cruise control.. my mg4 tends to rush up to the car in front then slams quite harsh regen on, even with different closeness settings.. much better to knock the speed back a little and be gentle about it. Smooth driving better than stop/ start..
