MG4 Software Update Thread
Infotainment update applies only for the Infotainment (MPU and MCU, although R63 doesn't have one of them anyway in the USB install, and R59's version is unchanged from R46 ... I think) - it does not update any other software in the car.
You need soME formal coMplaints to make them upgrade the infotainment system.
-My BT connection drops after a while. Phone sometimes refuses to connect.
-My HVAC is out of tune.
-I need to set it to 28 degrees before it keeps the car warm (these two arevsilved with a separate module update)
- the radio stops after some minutes and only comes alive after a reset.
Also check out if you can see external temperature. If not, ask for it.
And check if the left pull down screen contains the LKE icon. If not, ask for it. You need it at times (read your manual where it says to immediately disable LKA).
Even if car is already out of waranty?
So you are the cab driver? In that case, I assume all cost for your car reduces tax on business income? I would have it fixed for sure.
But get fixed what ? I prefer this to the new ac layout , and only had bluetooth problems lately which I assume are with an update on whatsapp.
    Votes: 934 77.6%
    Votes: 178 14.8%
    Votes: 91 7.6%
