Thank me later... (engineering menu)
I haven't been able to get a computer to recognize the device when connected to that port yet.
Does device manager (or equivalent on your computer) show any change at all as you plug it in? E.g. unrecognised device.
Ok updated. I passively converted the logic from Java to Javascript, but I didn't follow the discussion precisely. I also added info box.
Updated code at same url
I am unable to comprehend why my MG4 SE SR serial number is resulting in an incorrect password error. Have other users encountered this issue?
is the date on the car correct? The script uses today's date to generate the password
Try using uppercase letters and make sure your car has the correct date.
In case anyone is unsure, this is the serial number to use, not the VIN.
Ok, I just tested it with today’s code.
I found I did have to enter a custom date of 241011 even though it is the current date.
Leaving the date blank didn’t work.
I've discovered that on my MG4 SE, due to having older software R21, the password is visible in the logs. However, I've also noticed that it uses the time along with the date as a string, for example: '14/10/2024 13:00 is represented as '2024101413'. This suggests that in older versions, the password might have changed every hour, but they've probably removed the use of the time in newer versions.
    Votes: 1,052 77.9%
    Votes: 204 15.1%
